I have a 2 year old Panasonic E85H that is working fine, except that my commercial skip button on the remote is no longer responsive. I suspect that it is simply dirty after 2 years of use. Normally I would simply take the remote apart and clean the contact pad underneath the button, however, I have run into a stumbling block. I can't figure out how to open up the remote! I removed the batteries assuming the usual screw fasteners would be revealed, but there are none! I don't see any fasteners anywhere. I am reluctant to try prying it apart for fear of destroying it if there is some hidden secret to opening it up. Anyone have a clue about this?
Thanks for your time.
Ender
Why not just buy a new one? They might be on Ebay. You could buy one from Panasonic, I think they are about $29.
Also, you can use the time slip instead. Just push it, push for three minutes & then enter.
sony dvd recorder remote problem
By tattoojo in forum DVD & Blu-ray RecordersReplies: 10Last Post: 29th Apr 2015, 20:03 -
problem with TV GUIDE on Panasonic DMR-E85H
By ktnwin in forum DVD & Blu-ray RecordersReplies: 10Last Post: 13th Feb 2013, 18:21 -
Remote Control Problem with new Sony SR500H DVD player
By Bass Cadet in forum Newbie / General discussionsReplies: 3Last Post: 27th Jun 2011, 12:56 -
Remote Control Problem - Pioneer DVR-330-S
By wmedia in forum DVD & Blu-ray RecordersReplies: 4Last Post: 25th Mar 2008, 07:31 -
Really Strange Panasonic DMR-E85H Problem
By dafoe in forum DVD & Blu-ray RecordersReplies: 5Last Post: 19th Aug 2007, 09:04
