I bought a philips dvd recorder. It has many features & works fine with recording but the dvds dont work in any dvd i try to play it in. It says on the dvd player that there is an error loading or it just wont play. I have tried it in 3 different dvd players and i am wondering why it won't play. I record off of the t.v or off ON Demand from Comcast. If anyone can help it will be greatly appreciated.[/b]
what media are you using? dvd-r, dvd+r? dvd-ram? dvd-rw? dvd+rw?
tried diffferet dvd media brands?
are you finalizing / closing the discs? -
Have you finalized the disc? If you don't finalize it you won't be able to play it on another player. The one exception is Dvd+Rw. Those you can pop into another player without finalizing. BUT any other - or + R type disc needs to be finalized. Meaning you can't add more to it unless its a rewritable disc.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Are your players older machines? Some older machines don't like recordable discs.
Also, check this link for other compatibility issues.
http://www.dvddemystified.com/
recorded dvd won't play on computer or other players??
By wundahoss in forum Newbie / General discussionsReplies: 6Last Post: 9th Jan 2011, 17:55 -
home made DVDs wont play on all stand alone DVD players. why?
By suomiaussie in forum Authoring (DVD)Replies: 12Last Post: 2nd Jan 2008, 21:59 -
Can dvdr's recorded in the US play on UK/European players?
By WitchfinderGeneral in forum Newbie / General discussionsReplies: 2Last Post: 26th Sep 2007, 09:58 -
dvd burnt using avid wont play on some players
By cheesypuffs in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2007, 10:01 -
vcr wont play recorded tapes
By NatJm429 in forum Newbie / General discussionsReplies: 5Last Post: 20th Aug 2007, 11:46
[/b]
