Hello All, I need some help here, I'm using TMPEGEnc to Encode a DVD into SVCD (Child's Play). I'm using the NTSC Template and I went to and encoding it in 2300k bitrate, (is that a good bitrate?) so, i didn't want it Pan&Scan like it the orginal so I, changed the aspect ratio to custom and put in 480x320 i think lol, and so i went to source range and split the movie down the middle and when it was done encoding the movie was a 734MB, can u guys tell me wheather i should chop it to a 700MB or weather i can get a program that tells me if it can fit on 2 cds or 3cds before doing all that encoding. I dunno what to do help me
<font size=-1>[ This Message was edited by: hybrid on 2002-01-14 21:49:59 ]</font>
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
You can get 800 MB SVCD on a 80 minute CD. What's the problem?
hybrid,
don't burn dvd rips as regular data files. u need to use nero's (S)VCD templates to burn those .mpg files. that way you can fit ~750 MB on 74 min CD-R and ~800 MB on 80 min CD-R.
Help with svcd 2 dvd
By tastybaker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 11th Aug 2010, 10:30 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 11:05 -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 21:44 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18
