Results 1 to 9 of 9
    Dec 2006
    Canada
    I have a Koss DVD player that is supposed to play VCD movies but all I am getting is a no disc error. I am using memorex 700 mb CD's burned through both Otoker burner/converter and regular Windows (tried both). The files have been converted in Magic Video Converter. Is there some step I am not doing or is it a hardware/software problem?
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Does the dvd player play cd-r discs? Some will only play cd-rw discs. Check that and try again. Also try differnt blank discs. It might not like the brand your using.
    Dec 2006
    Canada
    Yeah, it plays CD-R according to the list so I guess I'll try a different brand. I have a Koss KS3102 by the way.
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    FYI make sure your disc is finalized. Don't have it be multisession. For vcd try something like vcdeasy - good software for vcd.
  5. I agree with yoda
    Try VCDEasy, it is more than the worth of its price
    Which Burner did you use earlier?
    আমি বাংলায় গান গাই
    Dec 2006
    Canada
    I tried using an old RW but that didn't work either. I guess I'll give this new program a try.
    Dec 2006
    Canada
    Woooot!! Thank you guys sooo much. VCDEasy works like a charm.
  8. Member yoda313's Avatar
    Jun 2004
    The Animus
    The right tool makes all the difference Glad you got it going.
    Aug 2003
    San Francisco, CA
    Some DVD players only play studio released VCDs!
