I've downloaded an avi with an srt file, but the subtitles are completely out of sync.
I've loaded it into Subtitle Workshop and tried to sync the first and last titles, but they're still completely off. mminfo tells me the avi is at 24fps, but I don't know what framerate the srt file was made for - I assumed it would match, but it doesn't.
Anyone know how I can figure out if frame rate is the problem? Arrgggh...
Mark
Did you use "Edit->Timings->Adjust->Adjust subtitles" to set the starting times of the first and last subtitle (NOT the ending time of the last subtitle)?
Did you try instead setting the "Input FPS" to different values while leaving the "FPS" at 24 on the left panel?
Worst case, some .srt files found on the Internet can had a very bad sync, and you'll need to re-sync them manually yourself.
Video and subtitle/sound sync problems in SubtitleCreator
By ditz in forum SubtitleReplies: 2Last Post: 20th May 2011, 04:12 -
Vobsub, Suprip subtitle sync problems
By leftspeaker2000 in forum SubtitleReplies: 4Last Post: 29th Apr 2011, 13:52 -
Subtitle Sync Problems in DVDit Pro
By aquaorbis in forum SubtitleReplies: 0Last Post: 5th May 2009, 22:40 -
Conversion size is driving me crazy!
By artdog in forum DVD RippingReplies: 8Last Post: 27th Apr 2009, 11:33 -
This file is Driving me Crazy! suggestions plz
By k_oss_22 in forum Video ConversionReplies: 2Last Post: 18th Mar 2008, 23:40
