I need to convert a Video Slideshow, VCD i think into images, the images are stored as dat files.
Any idea of some software that i can use to do this please
Andy
Open DAT file in VirtualDub, the select File -> Save Image Sequence.
That will save every frame from the source resulting in thousands of images. Since a slideshow shows the same image over and over, you can use Video -> Frame Rate to reduce the frame rate first. Try somthing like Convert to fps: 0.2 -- one frame every 5 seconds.
Player needs dat. file of avi files on disk
By karadeano in forum LinuxReplies: 9Last Post: 27th Jul 2015, 08:39 -
VCD dat files
By mayflower in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2009, 06:50 -
Advice needed on copying .dat files to DVD discs
By laval_ng in forum Video ConversionReplies: 17Last Post: 25th Oct 2008, 00:30 -
Do Divx dvd players play dat files?
By neo76 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 23rd Oct 2008, 21:27 -
How to create dat files?
By dimtim in forum ComputerReplies: 8Last Post: 6th Aug 2007, 07:03
