Hello Guys , Well i have a little problem , Yesterday i captured a movie from digital cable Tv using my Life View Fly Video 3000 Capture Card , And using Fly 2000 Tv Application and the PicVideo Mjpeg Codec well so far so good the capturing was smood no problem and the sound was ok with speeking , movie is 1H 42Min length and total size of 14GB , Now i try to compress the file with AutoGk to a total of 2 CD's and Fixed Width of 720 same as original now the problem i have is only with the 1.4Gb file (after compression With AutoGk) The sound is little bit not sync with speak , and the origin as far as i check is ok so why it is not sync after i compress it with autoGk ?
Any Help Will Be Great ! C ya ..
Results 1 to 1 of 1
Cable TV with 2 way splitter To 2 Tvs Singal Is kinda Bad Need Help
By DJboutit in forum Newbie / General discussionsReplies: 9Last Post: 13th Jun 2009, 20:57 -
Get digital cable into windows media center
By Simoyd in forum Media Center PC / MediaCentersReplies: 12Last Post: 17th Nov 2008, 09:50 -
digital cable = the new svcd format?
By mazinz in forum DVB / IPTVReplies: 38Last Post: 8th Jul 2008, 01:22 -
Bad SATA cable?
By CSULB71 in forum ComputerReplies: 9Last Post: 29th Mar 2008, 13:54 -
They want to sell me DIGITAL cable
By Faustus in forum Off topicReplies: 4Last Post: 11th Jun 2007, 09:03
