Ok, I got this thing about 2 days ago... and when I go to the Mpeg tools to merge&cut. When I edit a clip and select the starting and end points I get a little error message (although it doesnt affect me joining the two clips together at all, just annoying)
Now, here is my BIG PROBLEM. I cant join some mpegs because they aren't compatible. I looked at the TMPEGEncoder homepage and it says some stuff needs to be the same... well, is there ANY other program similar to Tmpegencoder that will change the files for me so i can join any mpeg (not expecting this)...OR a program that will let me change these properties so i can join them with other mpegs finalls.... PLEASE HELP, THANKS
Results 1 to 14 of 14
You can only join 2 MPEGs, that have same resolution, same bitrates, same everything. If they are different you have to reencode one.
Use TMPG to encode. Have a look at the "how to.." section. I am pretty sure, you will find a guide how to convert to MPEG.
no no... i know how to encode .avi to .mpeg, etc, but when i try to join the files (both being mpegs) it says they are incompatible, im guessing from the incorrect bit rate and all that, how do i change the bit rate, resolution, etc, so i can join them all?
Yes, reencode one of these mpegs with TMPG. You can load a MPEG-1 into TMPG directly. If it is a MPEG-2, create a dvd2avi project and load that as video source.
You can change the bit rate, resolution, etc by reencoding only. -
ok, i figured it out (thanks so much for ur help...)
still a few questions
it says i only get 30 days for mpeg 2 (maybe i selected it wrong?) how do i get more though if i cant get a full version (cuz there is none) is there a way around it?
i think thats about it... u have helped me with everything else, thank u so much (in case u want to know why i want to know this stuff... i wantto make some Dragonball Z Musiv video vcds =) and it will probably come in handy with future projects/things) -
hmmm, guess not.... ugh
Here is what im dealing with
File "X"
File "Y"
File "Z"
X and Y are the two files I want to join, but they are incompatible.
X = MPEG-1 320x240 30fps CBR 1150kbps, Layer-2 44100Hz 192kbps
Y = MPEG-1 352x240 29.97fps CBR 1150kbps, Layer-2 44100Hz 192kbps
(Thats what TMPG says on the bottom when I load the video and audio source)
Ok, so I went to settings and changed the resolution and FPS and then started to rencode.
I then got file "Z" (the new form of file "Y"
So then both Z and X were at = MPEG-1 320x240 30fps CBR 1150kbps, Layer-2 44100Hz 192kbps
yet, still they are incompatible and i cant join them....
ugh, whats wrong? was i supposed to change file X to become like like Y (i changed file Y to become like X , so Y re-encoded is Z) sorry if this is confusing.. but ah, what did i do wrong?
keep Y reencode x use the ntsc vcd template that comes with temge goto load and it will show you lots of different templates load the one I said and this new file will be C add Y and C to the merege cut spot make sure the spot where it says what type of stream says NTSC VCD the file from Y and C will BE GEEE see wasnt that easy Hope I helped
I don't kind of understand, you gotta be more specific, im a newbie.
Here it what I understood...
1 - Click on browse and select the movie I want.
2 - Click on load and choose the VideoCD(NTSC).mcf
3 - Click start, wait til done encoding.
4 - Click on file and go to MPEG TOOLS> then Merge & Cut
5 - "where it says what type of stream says NTSC VCD"
couldn't understand... I think you meant under TYPE: .. but the closest thing I found was *Mpeg-1 Video CD*
6 - Click run and enjoy.... didnt work though, still got an incompatible....
Argh...
So what I still need to know...
How to change the stuff, and what exactly, i need to change to make it compatible
How i know WHEN to choose the stuff (like templates when u brought that up.. i didnt even use it before...) how do I know which file to change, like leave X and change Y, how come i dont leave y and change x ?
Help is GREATLY appreciated.. remember im still very new to this.
-X -
Both files are not VCD compliant. However, to join them, they must be identical only.
File "Y" come close to the VCD standard, but the audio bitrate is different. If you reencode "X" using the VideoCD(NTSC) template, it will have a audio bitrate 224kbps.
To do list:
1] Reencode both files (choose each time the VideoCD(NTSC) template.
or
2]Keep "Y". Reencode "X".
1 - Click on browse and select "X"
2a- Click on load and choose the unlock.mcf
2b- Click on setting > audio, change bitrate from 192 to 224
5 - choose TYPE:*Mpeg-1 Video CD*
5a- add "Y" and "Z"
5b- choose a output directory and filename
7 - This .mpg file will not be VCD compliant. You can burn it as VCD anyway, but actually it is XVCD, that is not playable on all dvd players.>>>>>>go back to 1]
Ok, when i tried it... it didnt work...
Thewn after that, i just tried chanigng the fps (i think that was my problem before) and the rest, and it worked (im doing 1 more test on anotherfile right now s i write this)...
Still though, what is the deal with the Templates? someone please explain them to me...
sorry i am am bugging you, but i just dont understand (im sure u were all newbies to this program once)
Once again, Thank you all to who are helping me -
Ok, I figured out how to convert the mpegs so they are compatible... so my last question is....
What are the templates for? why do i need them, etc
thanks again -
A template is a textfile, that contains all encoder settings. Open it with notepad and you will see.
India becomes the king of the spammers
By Bonie81 in forum ComputerReplies: 0Last Post: 25th Apr 2012, 16:51 -
The King of Queens meets The Terminator?
By takearushfan in forum Off topicReplies: 0Last Post: 21st Jan 2011, 18:05 -
Mini DV is the king
By jazu in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 11th May 2009, 09:43 -
What is the deal with the f**king windowboxing?!?!?!
By explosionfoot in forum ffmpegX general discussionReplies: 9Last Post: 20th Apr 2009, 13:25
