2 Questions here First Off I am getting very bad out out of sync problems with TMPGenc or DVD2AVI not sure what one is causing the problem ,I have never had this problem before because im ripping straight from the DVD but it started after I installed XP ,anyone know what my problem might be ?
next one is I would like 2 encode GIRLS GONE WILD 2 VCD from the AVI I have ,I can watch the video ,it will open in VDUB but when I try in TMPGenc I get and invalid media type error ,So whats the Deal ?
Thank you very much for your help
<font size=-1>[ This Message was edited by: XanaXManX on 2002-01-10 21:25:58 ]</font>
Do you have the files for DVD2AVI and TMPEGnc in the same folder?
There is a file ???.vfp in DVD2AVI that needs to be in the TMPEGnc folder as well to open the .d2v file made by DVD2AVI.
Hope this helps u.
Yeah I have them in the same folder but that did not anwser my questions PLEASE HELP
You know, I had the same problem when I encoded GirlsGoneWild : uncensored and beyond, but all I did was open up TMPG and go to file new. Then open up the file without choosing any of the load templates. It worked for me!
P.S.- Maybe if you give out more specs about the movie, then it will help us out more.
P.S.S. - Which Girls Gone Wild do u have?? If I don't have it would u like to trade any movies??
What the Fuc is the internet? -
Hmmmm...if you could send me the file maybe I could take a look at it and figure it out.
Hehe I would think that a problem with capturing the video is that there are lots of jiggly objects flying around the screen....
Its an AVI and I cant be sure what type of AVI can I ?
how do I find out if its divx or whatever. All I know is that I can watch it but I cant open it with TMPGenc so I know that I have the Codec installed.
BTW I have lots of different GIRLS GONE WILD,NONE of them will open with TMPGenc ,I can also open them with VDUB ,Is there a problem with my TMPGenc and does anyone have any info on my OUT OF SYNC PROBLEM ,
Thanks for your help
P.S Insane at work now so I dont know what ones I have but I have 3 or 4 different ones so maybe we could do some trading
Browser makers are a bunch of whiny little girls
By guns1inger in forum Off topicReplies: 1Last Post: 8th Mar 2010, 10:11 -
Religiou service - gone wild!
By zzyzzx in forum Off topicReplies: 1Last Post: 14th Apr 2009, 13:11 -
cam girls not interested?
By Conquest10 in forum Off topicReplies: 1Last Post: 24th May 2008, 22:01 -
VirtualDub Gone Wild?
By solarblast in forum EditingReplies: 13Last Post: 15th Jan 2008, 19:32 -
Newbie confused. PC crashes/does wild when I attempt to record
By rob1974 in forum Capturing and VCRReplies: 3Last Post: 25th Aug 2007, 09:16
