Results 1 to 17 of 17
    Apr 2004
    tasmania
    I have purchased pirates of the carribean 2 and high school musical for the kids for xmas. I am tring to make backups before they scratch the originals.
    Shrink wont work, neither will ripit4me
    I am a novice so I need step by step instructions with no technical jargon
    Thanks guys, you are all such a great help
    Marni
  2. Member Dr. DOS's Avatar
    Sep 2004
    Mid Atlantic
    What kind of errors are you getting. You may also want to try CloneDVD (running with AnyDVD)
    Apr 2004
    tasmania
    Thank you Dr DOS
    CloneDVD2 did the job on High SchoolMusical - now going to try the other
    thanks so much!!!
    Now if only I didn't just have 21 days to use Clone hmmmmmm.....
  4. i used DVDFab and it came out perfect. Use that then, shrink it.
  5. Rip with DVDFab Decrypter, then use whatever ya prefer to reencode (IE dvdshrink, CCE etc)...
    Apr 2004
    tasmania
    I have now purchased clonedvd 2 and that is doing the job great. A word of warning though to any newbies - be VERY careful what you download and if it's a licenced program BUY IT!!!! don't believe the buggers offering cracks or free programs that are usually shareware- my system has been out of action and at the computer doctor for 2 days and $260 worth of work cos I let a trojan in while downloading something I shouldn't!!! I have learnt my lesson !!!!!
    Apr 2004
    Miskatonic U
    You have learned one lesson. But you still went and paid for software that does a function that can be done better for free. Your call, of course.
    Read my blog here.
    Apr 2004
    tasmania
    Problem is....I don't understand enough to work out what is good and what isn't. Shrink zipit4me and imgburner etc etc just wouldn't do it, whereas the clonedvd did, so I wanted to keep the program.
  9. Member lacywest's Avatar
    Aug 2001
    California
    I know someone who will most likely DVDShrink the POTC-2 DVD and keep every blooming thing on the DVD and end up with a lousy image on his TV.
    But with CloneDVD [I do own both AnyDVD & CloneDVD2] I can choose what to keep and what not to keep ... I really dont have use for a bunch of ... up coming movie attractions.
    As for picking up a trojan ... bummer ... Spy Emergency 2005 ... works nicely to remove the bad stuff. When you are going to those .... BAD/Dangerous ... sites ... don't give in to their Spyware installing demands.
    Those spooky websites have changed over the past year with more sophisicated ways and means to get private information from you.
    I bought Superman II -- The Richard Donner Cut ... and I ripped it with AnyDVD / CloneDVD2 and then shrunk it with DVD Rebuilder. I could have probably shrunk it with DVDShrink ... but I wanted to include the extra material included on the DVD about how it was made ... compared to the ... Superman II ... that was shown at the theaters.
    ontario ,canada
    Clonedvd works good as long as you remove all the useless unwanted stuff before re-encoding.Anything below 90% i use dvd rebuilder,or in most cases now just burn the whole disc to a dual layer.
    bmiller,ont.canada
  11. Member lacywest's Avatar
    Aug 2001
    California
    And what program replaces CloneDVD2 ... that is better ... for free ???
  12. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Ripit4Me to get your movie ripped and Shrink to reauthor to movie only - if you are reducing for DVD5 why put anything but movie on it ? DVD Rebuilder with HCEnc to do the re-encoding. All free and reliable.
    If you have ProCoder, even better.
    Read my blog here.
  13. Originally Posted by lacywest
    dvdshrink - it can remove the useless stuff too, and it is free
    Believing yourself to be secure only takes one cracker to dispel your belief.
  14. Member archaeo's Avatar
    Mar 2004
    mountains
    HC, Quenc, Shrink... all free
    ontario ,canada
    Not all the best things are free.Sometimes paying a few bucks gets you the better product.Clonedvd2 is a good program.Dvdrebuilder with cce is even better.
    bmiller,ont.canada
  16. DVDFab Decrypter and DVDShrink - FREE and does exactly what CloneDVD does
  17. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Shrink with Deep Analysis and AEC is visually as good, if not better than CloneDVD2 on the same disc. Depending on the disc and the amount of compression required, DVD Rebuilder will be noticably superior.
    If you like CloneDVD2 and feel your money was well spent, be happy. I, for one, am not convinced.
    Read my blog here.
