Results 1 to 14 of 14
    Dec 2006
    I just bought a panasonic 50' plasma TH-50PX60U. I want to hook up my comcast motorola HD-DVR box model DCT6412/2006 the best way. I dont know if I am using an HDMI. I also dont know if I need to update the firmware or get the newest updated box from comcast.
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Comcast should give you a choice of HDMI or Analog Component cables. Use HDMI if they give you the option. Easier in many ways.
    That TV has 1,366x768 native resolution. Experiment with 1080i and 720p as primary cable box output. Use which looks better to you.
    Set box to 16:9, HDMI, 1080i or 720p and 4:3 override to 480p
    Firmware updates download automatically. If you are having problems call them. They can take control of the box from their end or force a hard reset.
    Dec 2006
    That will help me alot. Thanx.
    Dec 2006
    New question. All is see on the back of the cable box is a DVI connection. Should I use a DVI cord? Or should I get the DVI to HDMI converter and a HDMI cord? Would the picture be that much better?
  5. Member edDV's Avatar
    Mar 2004
    Comcast 6412's come with either DVI or HDMI. Ask Comcast for a DVI to HDMI cable (assuming you have HDMI on the TV). They owe you the cable as part of the deal.
    DVI out carries no audio so you will need to run audio cables separately. AC-3 5.1 is only on the orange coax and optical port.
    http://www.kiva.org/about
    Dec 2006
    Thanx again. What would be the benefit of networking my cable box with my computer?
  7. Member edDV's Avatar
    Mar 2004
    Although there is an Ethernet port, it is currently inactive.
    Dec 2006
    How do I get a live cable TV feed through my PC?
    Dec 2006
    Also, should I hook my new Toshiba HD-A1 player up to the internet?
  10. Member edDV's Avatar
    Mar 2004
    S-Video and audio to a capture device or capture card.
    Dec 2006
    I dont know what that means but ED, you are the man.
  12. Member edDV's Avatar
    Mar 2004
    A device like this. Output will be DVD ready MPeg2.
    http://www.pricegrabber.com/search_getprod.php/masterid=3017802
    Or just use a standalone DVD recorder and be done with it.
    Dec 2006
    Does my monitor need to have PIP or that device does that?
  14. Member edDV's Avatar
    Mar 2004
    On your computer? It will be in a sizable window.
    Start using these boxes and it will become clear. Experiment.
