Two question in this TMPGEnc Xpress.
1) When I am setting output, the bitrate that the bitrate calculator gives me to put in, always makes the capacity GREATER than 100%. Is it better to set the capacity at 100% (thus smaller bitrate than what the calcuator suggested) or is it better to use what the calc suggested, go over (lik 105%) and then DVD Shrink it?
2) Resolution available is
720 x 480
704 x 480
352 x 480 ( i think this is the best one)
352 x 240
I am trying to make this for my small 7 inch dvd player in the car. Does it matter which one I select? I think someone said 352 x 480 will give me the best results for my needs, but I dont recall why. thanks guys
2. We need more information, how many minutes / DVD do you want? what is your source frame size/resolution?
i have about 6-7 hrs crammed of mpeg and avi music videos. my sources are all about 352 x 240 and 480 x 480
Xpress's DVD size estimate is a little on the low side - I also regularly encode 4 x 0:43 minute episodes onto a single disk, and always set the output size to 102%. This still fits easily, even allowing for TDA to create 5 animated menus (main + 4 chapter menus).
Trevor
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 16:07 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
