Well, ive tried many encoders including CC sp. But my question is, reguarding TMPGE for right now. This thing compresses so much the quality just sucks. The file im converting was from an after effects animation at 720x480 NTSC widescreen 16:9. Now all i want is to burn that to a dvd-r with no loss of quality. If TGMPG cant do that then how do u convert to .vob? Is .vob another dvd format with no loss of quality? Let me give an example. Ill show u the settings used for the mummy returns dvd. (not ripped but a retail version that i own)
Mummy Stats:
Video Attribute :
Video compression mode : MPEG-2
TV system : 525/60 (NTSC)
Aspect Ratio : 16:9
Display Mode : Only Letterbox
Source picture resolution : 720x480 (525/60)
Frame Rate : 29.97
Source picture letterboxed : Not letterboxed
Bitrate : 9.80Mbps
Now compared to my setup:
Video Attribute :
Aspect Ratio : 16:9
Frame Rate : 29.97
Bitrate : 9.80Mbps
To me it should be same quality, but for some reason this encoder is compressing way to much. The motion search precision is also set to highest quality(very slow) and still made no difference. What settings in the prog deal with compression and quality?
Results 1 to 1 of 1
TMPGEnc 4.0 XPress XVID Compression Confusion & Archival Suggested Setting
By timmer545 in forum Video ConversionReplies: 4Last Post: 26th Mar 2011, 11:54 -
TMPGenc xpress WMV compression help
By mikemar in forum Video ConversionReplies: 1Last Post: 21st Jul 2009, 03:02 -
more compression?
By jwfc in forum Newbie / General discussionsReplies: 2Last Post: 10th Jul 2007, 15:22 -
compression
By m-man in forum Newbie / General discussionsReplies: 5Last Post: 4th Jul 2007, 13:18 -
Compression
By Martig in forum Video ConversionReplies: 2Last Post: 25th May 2007, 22:17
