Hi all,
I used SmartRipper to extract the video from a VOB. Are .m2vs compressed at all?
- Justin
M2v is the file extension typically used for a video only stream encoded in mpeg2 format. Mpeg2 is indeed a lossy compression scheme, but that is how the video is actually stored in the vob file on the disc. You are not losing further quality by extracting using SmartRipper, if that was what you were worried about.
Would another way of saying it be that a VOB is a "container" similar to MPG but capable of much more (such as chapter points, etc.) and the M2V file is simply the video stream inside of the VOB? Just like an AC3 file or MP2 file would be the audio stream.
I don't mean to confuse things. Just hoping to unravel any misunderstanding I may have as well.
Output of both m2v AND ac3 during single "Render As" event in Vegas?
By Smells_Like_Feet in forum EditingReplies: 3Last Post: 28th Oct 2011, 19:08 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
Why do I have 2 files? "Movie Clip" and "M2V File"
By tygger in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2007, 21:55 -
Demuxing a "naked" vob to mpeg, m2v, etc
By engineer52 in forum Video ConversionReplies: 2Last Post: 13th May 2007, 15:39
