I have a video file of type *.avi
The video is xvid, while the audio is ac3. Unfortunately, my PMP doesn't support ac3 (without paying extra), so I would like to convert the audio to a different format. Can this be done? The guides I've found on this webpage seem to only deal with ripping audio from the video. However, I want to keep them together.
TIA
Virtualdubmod can do it. However, you must have an mp3 codec like lame installed. First, go to video and make sure direct stream copy is selected so that the video is not reencoded. Then go to streams---> stream list. Right click and then select full processing mode. Right click again and then select Compression. Select the lame mp3 codec and your encoding options. 128 khz CBR is good enough. Then go to file...save as....blah blah blah and wait.
I joined this site just to put a reply
i am very very pleased with ur turtorial its just alittle confuzzing so it took some time for me to understand all of it BUT i have to agree the AMC file thing was not there but the guy posted a link to it so its all good well thank u sooooooooooooooooooooooooooooooooooooo much its 4:30 in the morining and i started at like 2:00 lmao much love
Hannan291
(R.I.P dimebagdarrel)
srry for bump this
i did follow the guide worked but the audio get out of phase, any sugestions?
Converting AC3 to MP3 on AVI
By hilario in forum Video ConversionReplies: 22Last Post: 18th Jun 2011, 02:37 -
Attaching mp3 to video without converting?
By xtube in forum Newbie / General discussionsReplies: 4Last Post: 10th Aug 2010, 11:49 -
Audio out of sync after converting AC3 to MP3 in AVI with VD
By huykin in forum AudioReplies: 6Last Post: 1st Oct 2009, 14:27 -
Converting an AVI video with AC3 audio to an AVI video with MP3 audio
By rijulHKG in forum AudioReplies: 1Last Post: 15th Jul 2007, 01:23 -
Losing audio data converting AC3 to MP3, Help!
By blueprint in forum AudioReplies: 8Last Post: 24th May 2007, 15:55
