    Dec 2006
    Hi,
    I haven't been able to find a similar problem on the forum, and I am hoping somebody else has experienced this also and can share some wisdom.
    I have been using ffmpegX without incident to convert .rm files to .avi files, but one of my videos repeatedly comes out of the conversion with a duration of about 14 hours -- the 44 minute video that I want, followed by endless white screen. If I play the .avi in QTPro, it is 14 hours long, but if I import it to Final Cut, it is only the 44 min. that it should be...seems to make Final Cut crash though.
    Thanks,
    kcparker
    original video: .rm 400x264 pixels, 44.1/64 audio
    to .AVI (DiVX) MPEG4 [.AVI] (mencoder) 400x264, 3:2 aspect ratio, 24 fps, 48/128 audio
    Here's the process log:
    Encoding started on Fri Dec 1 09:35:01 CST 2006
    MEncoder dev-CVS-051126-18:35-3.3 (C) 2000-2005 MPlayer Team
    Mac OSX static build for ffmpegX
    AltiVec found
    CPU: PowerPC
    success: format: 0 data: 0x0 - 0x928c4ef
    REAL file format detected.
    Stream description: video/x-pn-multirate-realvideo logical stream
    Stream mimetype: logical-video/x-pn-multirate-realvideo
    Stream description: audio/x-pn-multirate-realaudio logical stream
    Stream mimetype: logical-audio/x-pn-multirate-realaudio
    Stream description: fileinfo
    Stream mimetype: logical-fileinfo
    Stream description: Video Stream
    Stream mimetype: video/x-pn-multirate-realvideo
    Stream description: Audio Stream
    Error: dlopen(/Library/Application Support/ffmpegX/reallib/cook.so, 1): image not found
    imetype: audio/x-pn-multirate-realaudio
    Stream mimetype: audio/x-pn-multirate-realaudio
    VIDEO: [RV40] 400x264 24bpp 24.000 fps 0.0 kbps ( 0.0 kbyte/s)
    [V] filefmt:11 fourcc:0x30345652 size:400x264 fps:24.00 ftime:=0.0417
    Opening audio decoder: [realaud] RealAudio decoder
    ADecoder preinit failed :(
    Error: dlopen(/Library/Application Support/ffmpegX/reallib/cook.so.6.0, 1): image not found
    on Support/ffmpegX/reallib/cook.so'
    Read the RealAudio section of the DOCS!
    ADecoder init failed :(
    opening shared obj '/Library/Application Support/ffmpegX/reallib/cook.so.6.0'
    opening shared obj '/Library/Application Support/ffmpegX/reallib/cook.bundle/Contents/MacOS/cook'
    Audio codec: [14] 64 kbps Voice
    Audio bitrate: 64.083 kbit/s (8010 bps)
    AUDIO: 44100 Hz, 1 ch, s16be, 64.1 kbit/9.08% (ratio: 8010->88200)
    Selected audio codec: [racookmac] afm: realaud (Mac OS X RealAudio COOK)
    Opening video filter: [expand osd=1]
    Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
    Opening video filter: [scale w=400 h=264]
    Error: dlopen(/Library/Application Support/ffmpegX/reallib/drvc.so, 1): image not found
    Opening video decoder: [realvid] RealVideo decoder
    opening shared obj '/Library/Application Support/ffmpegX/reallib/drvc.so'
    Read the RealVideo section of the DOCS!
    VDecoder init failed :(
    opening shared obj '/Library/Application Support/ffmpegX/reallib/drv4.so.6.0'
    Error: dlopen(/Library/Application Support/ffmpegX/reallib/drv4.so.6.0, 1): image not found
    CS!
    opening shared obj '/Library/Application Support/ffmpegX/reallib/drvc.bundle/Contents/MacOS/drvc'
    Selected video codec: [rv40mac] vfm: realvid (Mac OS X RealPlayer 9 RV40 decoder)
    Forcing output fourcc to 58564944 [XVID]
    Building audio filter chain for 44100Hz/1ch/s16be -> 48000Hz/0ch/s8...
    Building audio filter chain for 44100Hz/1ch/s16be -> 48000Hz/1ch/s16be...
    VDec: vo config request - 400 x 264 (preferred colorspace: Planar I420)
    VDec: using Planar I420 as output csp (no 0)
    Movie-Aspect is 1.52:1 - prescaling to correct movie aspect.
    SwScaler: using unscaled Planar YV12 -> Planar YV12 special converter
    videocodec: libavcodec (400x264 fourcc=58564944 [XVID])
    Writing AVI header...
    ODML: Aspect information not (yet?) available or unspecified, not writing vprp header.
    (in orange letters)
    Skipping frame!
    Skipping frame!
    Skipping frame!
    Skipping frame!
    Skipping frame!
    Skipping frame!
    Skipping frame!
    Skipping frame!
    Skipping frame!
    Skipping frame!
    Skipping frame!
    ad nauseum
    .076 [555:128] (black letters)
    Skipping frame! (orange letters again)
    goes on forever
    Skipping frame!
    1177171 duplicate frame(s)!
    Flushing video frames
    Writing AVI index...
    Fixing AVI header...
    Video stream: 29.484 kbit/s (3685 B/s) size: 190640223 bytes 51726.750 secs 80218 frames
    Audio stream: 128.000 kbit/s (16000 B/s) size: 827636352 bytes 51727.273 secs
    Encoding completed on Fri Dec 1 11:46:35 CST 2006
    moving you to the ffmpegx forum.
