If this question had already been asked, please direct my to the appropriate thread.
I am having trouble connecting my Motorola HD DVR cable box to my Toshiba HDD DVD recorder. I am assuming I can feed the signal from the cable box into the DVD recorder thus allowing me to record the channels from my cable box. Which cables work best? Which outputs and inputs should I be using? What channels should I have my television set to? What channel should I have my DVD recorder set to?
Thanks in advance for your help.
Jason
depending on the cable box you should have RCA and RF outputs. RCA should give better output with separate video/stereo sockets (white,red,yellow) or better yet S-Video cable. Toshiba's have IR blaster allowing PVR to control cable box. Check your manual. I can't imagine that there's no schematic diagram showing clearly how to connect the two. If you have no manual go to the Toshiba site to get one in pdf.
Recording from DVR Cable Box to DVD Recorder crops the sides
By Bumbie in forum DVD & Blu-ray RecordersReplies: 4Last Post: 2nd Jan 2012, 14:40 -
Problem: DVD-R Recording with Motorola QIP6416-2 DVR FiOS TV Box
By Plarocks in forum DVD & Blu-ray RecordersReplies: 12Last Post: 4th Jun 2010, 20:03 -
Help hooking up Panasonic DVD recorder to Comcast cable HD DVR
By KeithJFro in forum DVD & Blu-ray RecordersReplies: 10Last Post: 22nd Feb 2010, 17:17 -
By KeithJFro in forum Authoring (DVD)Replies: 2Last Post: 22nd Feb 2010, 15:20 -
Hooking up an LCD monitor to Verizon Fios cable box
By JKam2000 in forum DVB / IPTVReplies: 2Last Post: 2nd Oct 2009, 02:41
