anyone have experience capture long shows such as sports events in half d1 (352x480) in order ot fit into dvd-r? what's the optimal settings in cbr value or vbr range to use? is 352x480 as good as a vhs tape in standard mode? is this playable on most sony, samsung, generic players?
trying to decide if i'd wanna record in half d1 or recording SP mode at 720x480 and split the file in two since don't have dual-layer disks.
using wintv pvr usb 2.
will be watching on my 300lb 36" sony crt tv from 10 years ago...yikes...
Calculating CBR settings for X minutes to take up Y bytes is a simple division (Y / X), allowing first for authoring and VOB overhead.
4,500,000,000 bytes / 210 minutes ~= 2857Kb/s.
For VBR, that would be your average, then for best compression results, use as wide of a min/max range as possible.
Toshiba Camileo H2O and Osprey 210 capture card?
By Amanda28 in forum Capturing and VCRReplies: 1Last Post: 17th Nov 2009, 13:12 -
Gotsent Sound Problem! 1st Half 2-Channel 2nd Half 5.1?!?
By Jerec in forum Video ConversionReplies: 1Last Post: 7th Aug 2008, 13:16 -
How Do I Split screen Half Rolling Credits-Half Video in Vegas
By Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 08:35 -
352x480 Half D1 Mpeg2 to Divx - How do I keep proper aspect ratio (40:33)?
By stizz in forum MacReplies: 16Last Post: 8th Feb 2008, 01:24 -
Q: Adaptec AVC-2310 MPG2 Capture - Need: Shrink/Fit to DVD, Redo Audio
By jpneok in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jun 2007, 19:06
