Hi,
when running ffmpegx about 3gb of hd space went away...
only have a few mb now because I trashed things away...
where are their files on the hd from ffmpegx?
thx alot
The files are where you saved them. Unless you altered things prior to pressing the "Encode" button, the partially completed conversions are in the same folder as the source video file(s).
Sounds like you need to clean off more than just the partially completed conversions, however. If you only have 3GB free space, you'd better trash some other things, too.
hey, launced 3 operations at one time, went to sleep then..., so one was running, others in queue
(needed to test some things with subtitles)
i know i should do some cleaning... but it's not really the problem now...
just wanna know where those files from ffmpegx that fills op the rest of my disk are...
The temp files are in the folder in which you were going to save the video. ffmpegX will (or sometimes may not) delete those files when the encoding is completed. It does not store any invisible files or put anything in a non-obvious location.
If you used "Decode with mplayer", then in some cases a temp file may be written instead of a 0 bytes throughput pipe. To find it, use a program like OmniDiskSweeper.
Does recoding a 7gb mkv file require a lot of hard disk space?
By dave in or in forum Video ConversionReplies: 3Last Post: 21st Aug 2011, 17:01 -
Exporting a little movie file that won't consume my entire hard disk space
By Danny Pro in forum Video ConversionReplies: 5Last Post: 14th Feb 2010, 23:50 -
Burning iso image from Hard disk to hard disk?
By When in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2008, 22:27 -
hard disc 1 died, hard disk 2 won't boot, halp!
By Yoroshiku in forum ComputerReplies: 6Last Post: 30th Oct 2007, 13:48 -
Hard Disk Space When Encoding
By Em in forum Newbie / General discussionsReplies: 8Last Post: 21st May 2007, 12:35
