how to put word balloons on the characters on my video... what program can i use? and i like to put animations such as change the persons face can annyone suggest the program to be used?
After Effects, Combustion, Wax2 and WinMorph. If you know your editor and photoshop well enough, you can use those. How simple or how complex it is depends on the type of effect you want. If you want smooth animation, it is difficult and time consuming. If you want something simple, it is pretty easy.
Read my blog here.
Trouble Editing/Trouble Base Media?
By SlickPen in forum EditingReplies: 0Last Post: 20th Mar 2011, 19:53 -
Why does XVID avi file balloon in size when converting to mpeg2 or dvd?
By im2020 in forum Video ConversionReplies: 3Last Post: 11th Aug 2010, 12:30 -
Trouble with OE
By alegator in forum ComputerReplies: 4Last Post: 6th Feb 2009, 14:52 -
PS/2 Trouble
By gooberguy in forum ComputerReplies: 22Last Post: 19th Jun 2008, 18:08 -
Having Trouble With DVDFAB
By Dr_Shakalu in forum Newbie / General discussionsReplies: 3Last Post: 20th Dec 2007, 15:56
