hi ppl good day. Sorry im new here. I try to search around and could not find a best answer to it.
I have a few video under RMVB and i have convert them to AVI. But the AVI file size is too big. 2 file already take up the whole DVD disk of 4.7GB.
Im using WinAVi. Anyone can advise me on how to get to a small file size?
could it be my avi encoder? if yes which you recommend me to use?
Thank You
it all depends. We need more details.
When you're using the AVI converter, What do you have your compression set to for your video output?
AVI is just a container and the codec that you use to compress it is your formate. Other than that, there are better programs out there to use to convert. Yeah, they might cost some money but there worth it. I use HT MPEG Encoder 6.0 and it helps big time. The problem with AVI is that there are so many codecs out there for AVI. There are only a few Codecs (Compressors) that will bring down the file size.
If you're going to use this file for DVD, you should look for a MPEG-2 (Layer 2) because that's what DVD Burning Programs use when there being burn.
Check your AVI converter and let us know what comression you're using.
Cheers
Murray -
hi sorry for the late reply. Hmm from what I see in the advance I saw this but Im not sure which one to choose so I leave it as default.
I don't know which one to choose but I need something like good quality to it but I want to burn as many file in one disk
sorry if im asking some noob question.
I give a try on HT MPEG Encoder 6.0 [I waste a few disk already]
After I have d.l HT MPEG Encoder 6.0 I just look for mpeg will do to do the convert?
And one more things is I just got my LG H12N dvd writer. May I ask in order to use my 18x speed I must get a disk which is also 18x? -
sorry can i ask HT MPEG Encoder 6.0 is something that help me to convert RMVB to AVI? or is a program help me compress after I have convert to AVi?
cause I dont seems ot be able to read rmvb file using this program. ;/ sorry im too noob
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
File size differs from data size--HUH?!
By atoledo123 in forum MacReplies: 2Last Post: 9th Sep 2011, 13:19 -
Help converting small size but large stream size asf video stream file?
By apple4red in forum Video Streaming DownloadingReplies: 5Last Post: 11th Oct 2010, 11:01 -
Question: MKV File Size vs MP4 File Size
By VideoNoobz in forum MacReplies: 6Last Post: 20th Feb 2010, 02:44 -
Advice Request regarding TMPGEnc, File encoding, and DVD creation w/ Menus
By Hal05154 in forum Newbie / General discussionsReplies: 9Last Post: 25th Sep 2007, 13:13
