how do i (simply if poss) stretch a widescreen film , or part of to full screen so i lose the black bars top and bottom .......... probably a stupid question but its doin me nut in ......... lose too much of the image on me phone when i get stuff on to it
You can crop off the sides, similar to the 'pan and scan' they do when they convert a movie to TV format. Depending on the video format, you could use VirtualDub or TMPGEnc encoder it it were a AVI type format or a MPEG.
Or you could resize it if your player can accept other framesizes. You may have to resize it anyway to make it fit after cropping. -
thanks for reply.......... really
but ......... i'm a total novice/idiot with all this
i kinda see what your sayin .......... and almost get it
so ........ i need to put me dvd in ....... convert to say mpeg
then i can play about with cropping ??
see all i wanna do .
i got a couple of films that i would like parts of on me phone , they make me laugh .......... hopefully others will laugh too
they are both in widescreen format ...... or whatever the technical name is .....
......i dont know if i've joined the right forum for advice on this or not ....... i was pointed in this direction by a mate ..................... if its wrong for me to ask this here or i aint welcomed then please forgive me and maybe someone can tell me where to go
for about a week for more i just been tryin to find out the
easiest/simplest way of puttin a dvd in me computer , cuttin the little 2 to 5 minute bit i want ...... and gettin it to play on me phone ............ there must be a way for idiots to do this ........
i see so many about it really cant be that hard to do
................................ or is there some trade secret????????? -
Yes, it's a secret.
It does take a bit of studying, unfortunately. But, you could convert the whole DVD to a large MPEG file with VOB2MPG, then do your edit/crop/resize. Or you could use VirtualDub Mod and drop in one of the VOBs that has the video clip you want and save it out as a format that your phone can play, along with crop/resize.
A lot depends on what format your phone uses for video. Or you could output from VD Mod in a lower compression format to preserve quality and use a program like SUPER that may very likely be able to produce a video your phone can play.
BTW, those are all freeware programs.
Hi....
If you want to use virtualdubmod for resizing the widescreen the picture will look a bit strange...
the blackbars wont show up in the preview window because the video picture has the format 720x576 (PAL)
or 720x480 (NTSC). You must know the aspect ration of the video ex 2.40:1 ,2.35:1, 1.85:1 or 1.78:1...
and resize the video into the right format...
2.40.....720x300
2.35......720x306
1.85......720*389
1.78......720x404
After that you must resize the video into the format which your phone will accept...
stars..... -
cheers for that .............. looks like a weekend of fun and games ahead for me
will try what you suggest many thanks -
Unlikely it matters if the aim is to crop video, the most important thing here is to keep the correct displayed aspect ratio at cropping and resizing. The ways will be different for DVD- and avi- sourced videos.Originally Posted by stars
1.If the source video is square-pixelled (avi) and the aspect ratio is correct, then it should be cropped to target displayed aspect ratio (e.g. 4:3), of course if the video had horisontal borders, they should be cropped first. Then it can be resized:
a)keeping AR if the target format is avi,
b)to 720x576 if the target is PAL DVD, for further MPEG encoding.
2.If the video is from DVD it should be resized first to 16:9 displayed aspect ratio, then borders (if there are any) cropped, then the side parts of video cropped to get target AR and then the video resized to target size as above.
Convert avi to 16:9 widescreen
By sknoxxx in forum MacReplies: 4Last Post: 28th Aug 2009, 20:50 -
Convert Pseudo Widescreen to Proper Widescreen
By simonw2008 in forum Video ConversionReplies: 5Last Post: 5th Apr 2008, 20:57 -
Convert letterboxed widescreen to anamorphic widescreen?
By ziggy1971 in forum Video ConversionReplies: 6Last Post: 7th Mar 2008, 22:15 -
Convert 4:3 TV CAP of 16:9 to True 16:9 Widescreen
By rkr1958 in forum Video ConversionReplies: 3Last Post: 6th Jul 2007, 14:37 -
Video won't convert to Widescreen
By RogMcDodge in forum ffmpegX general discussionReplies: 1Last Post: 12th Jun 2007, 14:46
