  1. Member stackner's Avatar
    Mar 2004
    Digital World, Australia
    what i want to know is how to view the vista build number on your desktop with the RTM (FINAL) build? what i mean is like with all the beta's when you installed them they showed the COMPLETE build number on the lower right of the desktop. the RTM (FINAL) build does not do this. is there a way to get it to show? cheers.
    Open a command prompt and type ver
    My vista rc2 version:
    C:\Users\sed>ver
    Microsoft Windows [Version 6.0.5744]
  3. Member stackner's Avatar
    Mar 2004
    cheers. very close to what i want although i can see that much in system info or such. in want of the whole long build string. i do not have one of the beta's installed currently as i have the rtm installed so i can not show what i mean but by default with all the beta's and rc's it shows this LONG build number (extra info or such) on the desktop at the bottom right (if you have the task bar set to autohide/minimise.)
    My rc just shows
    Windows Vista (TM) RC2
    Evaluation copy. Build 5744.
    but maybe did the beta versions show more info.
  5. Member stackner's Avatar
    Mar 2004
    dunno. ive had most the betas and rc1 and both rc2's and remember them showing more. its cool anyway. just wanted that desktop bit thats in the betas rc's but doesnt look like its in the rtm
