Is there any program for making DVD menus, that isn't overly complicated to use, and has better adjustment options than DVDLab Pro? I want to make a menus with several buttons within the same box, and aligning them up (having them in the middle of the box, and having the exact same space difference between each option) is far too based on-eye with DVDLab.
Thanks for any help,
Cyan~.
Almost all authoring softwares allow you to create menus/motion menus. Ulead Studio, Ulead DVD Movie Factory, Sonic DVDit, DVD Architect, and others. Just download some trials and see which ones you like, then buy them.
Rob -
why don't you click on the snap to grid button on the main toolbar of dvdlab pro, so that you can align your buttons precisely.Originally Posted by Cyan
Encore DVD Menu Authoring
By montgal in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th Apr 2012, 23:24 -
Authoring DVD without a menu?
By Humptydank in forum Authoring (DVD)Replies: 6Last Post: 29th Mar 2010, 16:55 -
how to keep original menu and not re-encode files by dvd authoring
By deejay.2001 in forum Authoring (DVD)Replies: 8Last Post: 1st Sep 2008, 02:08 -
dvd authoring with hidden menu
By VeryNewbie in forum Authoring (DVD)Replies: 1Last Post: 21st Jun 2007, 03:21 -
DVD Authoring: Menu Creation, Encoding, etc
By kerpal in forum Authoring (DVD)Replies: 7Last Post: 20th May 2007, 18:27
