After days and days of experimentation and research of learning about video compression, I finally realized how people get some of these DivX/XviD files to look so mind-blowingly good... I'm pretty sure it's through the use of filters. Like "Smart Smoother High Quality" and etc. Now I guess these filters are normally deployed through Virtualdub or Avisynth...
My question is, is it possible to enable these filters somehow to be used with Fairuse Wizard? How exactly does fairuse wizard work? I swear I saw it launch virtualdubmod at some point. Would there be a way to enable these filters then to be used in Fairuse Wizard's encoding?
Thanks in advance.
Any reason why it needs to be Fair Use Wizard? Gordian Knot is another great app and allows you to use AVIsynth filters (btw, check out "SeeSaw" and "FFt3dfilter" from the AVIsynth world -amazing)
Yes, I want to make it as simple as possible. I want to have an all-in-one dvd->xvid program, in which I can graphically select clips of the movie to rip if I don't want the whole thing. It has to be easy, something that my girlfriend (non-computer geek) can use.Originally Posted by Soopafresh
Haali Media Splitter, LAV Filters, AV Splitter...How do these filters work?
By Moontrash in forum Software PlayingReplies: 3Last Post: 25th Feb 2012, 18:00 -
Fairuse Wizard
By Simmons in forum Video ConversionReplies: 1Last Post: 17th Aug 2011, 18:34 -
Fairuse wizard
By pensioner in forum Newbie / General discussionsReplies: 2Last Post: 26th May 2010, 12:37 -
[Solved] Question about MPlayer filters in FFDShow and Mencoder filters
By BlooderButcher in forum Video ConversionReplies: 4Last Post: 24th Nov 2008, 11:32 -
fairuse h264 5.1
By dartmania2002 in forum DVD RippingReplies: 0Last Post: 21st Jul 2007, 16:52
