I need software or guide to convert wav or ac3 to mpa (mpeg audio)
thanks..
Why? What do you just need the MPA conversion for (not that you don't need it, but just curious)?
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
its not working..unsync
its an mpv (the video) and besweet(diko) dont encode the audio well and in the end of the movie there is no sound!
so, i think that if i encode the sound myself it would fix
ohh and i multiplex with TMPGENC, which type should i choose in the simple multiplex???
ty
edit:
i used belight and in "presets" i choosed mp2-->DVD -
Where is it unsync'ed? Why are you using MPEG audio? What is your application?
Since it appears that you are trying to make a DVD, why don't you just keep the original .AC3 file?
A lot of us here are super mind readers, but I find when I do it for cases like this, it hurts my head.ICBM target coordinates:
MPA to AC3
By Benjy in forum AudioReplies: 6Last Post: 14th Jun 2011, 06:52 -
How does one process mpa and mpv files?
By mysts in forum Authoring (DVD)Replies: 2Last Post: 11th May 2011, 13:30 -
How to compress mpa stream
By jeby1980 in forum AudioReplies: 2Last Post: 23rd Feb 2010, 17:01 -
Convert ac3 to mpa
By pcb in forum AudioReplies: 3Last Post: 5th Jan 2010, 12:39 -
Mpa to ac3 5.1
By garherd in forum AudioReplies: 6Last Post: 3rd Sep 2007, 18:43
