When trying to frameserve DVD/MPEG2/HDTV to an advanced video editor I keep getting audio sync problems. I'm using this tutorial:
https://forum.videohelp.com/viewtopic.php?t=261416
When I'm using DGIndec, less than half way through it says Audio Error (yet it continues to make the WAV file).
Does anyone know how I can fix this problem?
PS - I used DVDFab Decrypter to rip the DVD to my hard drive. I kept getting errors using DVD Decrypter.
After using DVD Fab Decrypter you should run the results through FixVTS. This can correct errors left by the removal of structure protection.
Read my blog here.
Thanks for the tip, I'll try this.Originally Posted by guns1inger
Annoying video/audio sync problem
By WebMaximus in forum DVD RippingReplies: 2Last Post: 12th Nov 2011, 08:59 -
Audio video sync problem
By FrankieToh in forum Newbie / General discussionsReplies: 0Last Post: 3rd Dec 2010, 08:53 -
How to frameserve DVD/MPEG2/HDTV to an advanced video editor
By Baldrick in forum User guidesReplies: 55Last Post: 14th Feb 2010, 11:22 -
Audio Video Sync problem
By m baqar in forum Authoring (DVD)Replies: 1Last Post: 27th Mar 2008, 01:59 -
Audio/video sync problem
By Hekey Williams in forum DVD RippingReplies: 1Last Post: 8th Oct 2007, 05:27
