Hello,
i was just wondering if anyone had any suggestions, which card can anyone recommend? I'm in the UK, so it would be greatly appreciated if anyone can suggest a place i can get one from over here!!
thanks alot
Its not just the card to consider but what is also included will depend on the packages price .
You would need to look about ... but I grabed one that came with the ieee cable , driver cd , and full version of ulead video studio 9 for $28.00au in ebay .
Via chipset :vt6214L and vt 6306 ... 4 port usb2 (5 onboard) , 2 ieee ports (3 onboard) ... manufacturer = non-identified -
I see that you are also thinking of buying the Pioneer 111, may I suggest the following -
http://svp.co.uk/products-solo.php?pid=405
http://svp.co.uk/products-solo.php?pid=1020
http://svp.co.uk/products-solo.php?pid=1461
If you buy the disks as well the shipping is only 99p.He's a liar and a murderer, and I say that with all due respect.
Does anyone make a FIREWIRE 400/800 COMBO HUB?
By KeepItSimple in forum MacReplies: 16Last Post: 20th May 2011, 16:25 -
Verbatim 3.5'' External eSATA & USB Combo Drive 1.5TB
By kyrcy in forum ComputerReplies: 2Last Post: 8th May 2010, 10:00 -
Verbatim 3.5'' External Hard Drive eSATA & USB Combo 1TB
By kyrcy in forum ComputerReplies: 3Last Post: 19th Feb 2010, 08:44 -
USB or firewire
By rjack in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2009, 21:42 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 11:19
