How can I put 5 buttons on one page, instead of 2 4 6 etc.?
And if not, how can I change the button that goes through the pages
of the menu's? 'Cause it's green!
Kate: What's the big thing that happens every Monday at one o'clock?
Tom: The dog outside the pub scratches itself...?
Kate: The plane from Broken Hill arrives! -
This is technically an authoring issue, and you most likely won't get much assistance as this is a Nero product. None of the Nero products are very popular because of their poor quality. There are many better (some free) products available.
Google is your Friend -
Can you recommend me one? ( Which you think is best )
I don't tend to author many dvd's. Take a look in the software section for authoring programs. Some are free, many have a free trial.
You can also browse the HOW TO - AUTHOR section for guides. You will then be able to see what software is used and what it can do.Google is your Friend -
I myself use NV3 and I don't really know a way around that except when I have the MPEG-2 files ready beforehand. (In fact you should always have your video DVD compliant before NV3 since it sucks as a converter.)
If you want 5 buttons, it's best to divide before, and load your video as 5 seperate MPEG-2 files into NV3 so the app can read them as 5 different entities and assign 1 button to each. With the proper layout, you can get them on one, two or three pages.
Or assign chapter points if the video is on less than 5 titles and select buttons for chapters and titles. If any video file/or separate title does not have a starting point for one of your buttons then you would have to do some combining beforehand.
I'm not sure exactly what you want the 5 buttons for, but it's best to set up your video before you load into NV3.
As well, if you don't like any of the buttons, or colors, that is not a problem. I personally use an image processing software app to create my very own buttons, and I insert them into the "Buttons" folder where NeroVision was installed. You can pick one you want to change, edit it and save it as another separate button. (Save them as well seperately in case you want to reformat your hard drive someday and want to use them again.)I hate VHS. I always did. -
Originally Posted by PuzZLeR
Thanx for all the other info though!Kate: What's the big thing that happens every Monday at one o'clock?
Dolby problem in Nerovision 3
By SuperJman in forum EditingReplies: 1Last Post: 3rd Dec 2008, 04:13 -
Nerovision maximum bitrate
By whenloverageswild in forum Authoring (DVD)Replies: 6Last Post: 11th Oct 2007, 08:40 -
Is somebody a NeroVision Express expert?
By jeanpave in forum Authoring (DVD)Replies: 12Last Post: 15th Sep 2007, 22:42 -
NeroVision 3 Sample format?
By LiBiDoXP in forum Video ConversionReplies: 0Last Post: 1st Jul 2007, 12:50 -
NeroVision problem
By Flying Doctor in forum Authoring (DVD)Replies: 10Last Post: 23rd May 2007, 00:52
