    Jul 2004
    I tried using the reauthor Tab for extracting a partial file from my disk, however Backing Up the file only extracted the show minus 5 minutes at the end. How did this happen?
    I dragged and dropped the correct show into the left column and it played in DVD Shrink all the way through, but when going to burn, it only had the show minus 5 minutes.
    Please help Thanks
  2. did you use the slider bars for both the beginning and ending parts of your final movie? previews should have been available. also the numbers on the bottom tells you how big the final filesize will be.
