Can someone tell me what the *quickest* way to rip a DVD is?
The quickest way I can think of is:
1. DVD Shrink.
2. VirtualDubMod.
(Assuming all needed filters and other bits and bobs are installed.)
Is the above a good/bad idea?
Is there a more optimal and faster solution?
Quality is really important - so I don't want to spare on that part.
Thanks.
OM
sorry... I should have said: yes.
also... not sure how possible this is... but i would really really like an automated solution as possible!
i.e.: just stick the dvd in and press one button say.
is this possible? -
Try FairUse Wizard. It should do most of that fairly much one touch. You may need a program like DVD43 or AnyDVD for a front end to decrypt some of the newer DVDs.
that looks pretty good to me.
thanks.
without having tried myself yet... can you tell how long it takes to rip a dvd?
thanks. -
The ripping usually takes 25-40 minutes. That's just copying the DVD data to the harddrive while removing the copy protection.
However, depending on your CPU, the encoding to shrink the from a 7+ GB disk to a 4.3 GB disk can take an hour or more. And then the burning is another 8 min. or so depending on write speed.Some days it seems as if all I'm doing is rearranging deck chairs on the Titanic
What's the quickest/easiest way to cut something from DVD and DivX
By dsajkw in forum EditingReplies: 2Last Post: 2nd Sep 2010, 12:50 -
Quickest method of converting avi to DVD ???
By blinky88 in forum Video ConversionReplies: 15Last Post: 10th Oct 2009, 02:09 -
Quickest way from Camcorder to DVD
By Priapism in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 25Last Post: 26th Aug 2009, 14:07 -
What is the quickest way to get an mpeg onto a playable dvd?
By pugvader in forum Newbie / General discussionsReplies: 4Last Post: 1st May 2009, 15:57 -
Quickest Way to Rip My DVD's?
By Rjupiter in forum Newbie / General discussionsReplies: 16Last Post: 19th Mar 2008, 14:11
