Hi all,
I am trying to work out what is the most real to life aspect ratio to use, i mean 4:3 you look fat and short, 16:9 you look slim and tall.
So what is the best aspect ratio to use so it looks closest to real life as possible? or is their an aspect ratio that your eye see?
Thankyou josel
The ratio that the image was created in.
If you have a 16:9 image and play it back at 16:9, it'll look normal. If you play a 4:3 image at 16:9 it'll be stretched wide.
If you really can't tell what it should be, look for objects that should be perfect circles or squares and try changing the viewing ratio until they are correct.
There's an infinite number of possible ratios, but in practice most are either 4:3 or 16:9, or close enough to pass.
aspect ratio
By devdev in forum Video ConversionReplies: 5Last Post: 19th Apr 2012, 18:31 -
Aspect Ratio
By ping182nz7 in forum EditingReplies: 12Last Post: 26th Apr 2010, 14:30 -
Aspect Ratio
By jackowens in forum Video ConversionReplies: 2Last Post: 18th Mar 2009, 18:40 -
16:10 Aspect Ratio
By SWBisbee in forum Newbie / General discussionsReplies: 4Last Post: 31st May 2008, 02:41 -
what is aspect ratio?
By mai_hnf in forum Authoring (VCD/SVCD)Replies: 3Last Post: 29th Sep 2007, 23:29
