Results 1 to 10 of 10
    Oct 2006
    Canada
    Hi.Mine burner wont read any discs.It did yesterday now all i hear is a noise from inside like it tries to read it or something.Anybody know what could cause it?
    Oct 2006
    Canada
    Could it be that the laser got damage?
    Dec 2002
    Costa Rica
    Dust in the lenses?
    Gatineau,Quebec
    I had a problem in the past with a cheap Apex 1200 dvd player and the lens was stuck.
    I saw a web site with people who had a lot of the same problem.
    You open the dvd player and just push the lens sligthy.
    Then after the problem was solved.
    Maybe its the lens taht is dirty.
    If your player is still under warranty dont do it! Send it back.
    Mine was a cheap one, thats why i tried it.
    Good luck
    Vive le Quebec libre!
    Oct 2006
    Canada
    Cool but my problem is with a dvd writer not a dvd player.Tomorrow i will use a lens cleaning cd and see if it helps.
  6. Banned
    Dec 2005
    Canada
    remove and reinstall it (in dev. manager), if no help you may tinker with it for a while but what's dead is dead. Drives are cheap...
    Oct 2006
    Canada
    dev.manager??You mean take out out and unpluge it,then plug it again.I can't reinstall the software cause i have it on a cd and that writer was my only cd/dvd rom
  8. Banned
    Dec 2005
    Canada
    right click on it in dev. manager and uninstall then reboot. google for "dvd won't read" I recall seeing once a patch to reset the drive, possibility is it's dead but maybe you will be able to revive it somehow.
  9. Member oldandinthe way's Avatar
    Mar 2006
    With the other crabapples
    Go to the LG forum at
    http://www.cdfreaks.com
    Your drive may need lubrication. There are detailed instructions available there.
    XP should be able to reload the driver for your drive without a CD. It certainly can for my LG drives.
  10. Sorry I can't help you...
    But I do have a problem of my own with a new LG Burner I got that came with my new notebook. I am using a LG DVD-RAM GMA 4082-N trying to burn a Memorex DVD+R DL (its the only DL media I could find at the time). When I input the media in the drive and burn with Nero my drive tells me it is not a DVD DL but rather a CD-R. Is this problem most likely due to the media or do I need to update firmware? Any help would be appreciated!
