  1. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    whats the best way? as of right now i use super to encode straight from vob's with seems to give me great quality but the only prob is i get multiple file...so then the only thing ive found is apecsoft avi 3gp joiner witch puts them back together into one big file which i want but im not sure of the quality after that step x.O
    is there a better way to get a dvd just to one big quality file to watch movies on my phone? tryin to keep it to an easy two step process.
    this is for my tmo samsung t609 btw
    vob2mpg -> super
    or
    Nero Recode and make mp4 files...i think your mobile supports it.
  3. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    see the vob2mpg route is what im looking to avoid long encodes since my cpu's are stuck in the year 2004'ish :/
    ill look into nero. thanks. and im honored that baldi boy himself replied to my thread
  4. Hi there, I am new to watchng movies on my phone, but have looked into it a bit. I am currently using a free program called SPAM, which you can find easily with a google search. It rips right from the DVD and does the conversion. So far, with limited experience, it seems to work ok. Hope this helps.
