Hi! I have downloaded and burnt DVD's very successfully with DVD shrink and Magic DVD, but am having trouble with AVI files. I downloaded 'Forbidden Planet' in AVI format and it plays perfectly in Windows Media Player. (When I right click the file - it says frame rate 23 frames per second, which doesn't sound like PAL or NTSC!)). However, when I convert and burn this AVI file with DVD santa, and ask for the DVD to be PAL, the end result has a little pause every couple of seconds. I have seen this effect before on copied DVD's. Apart from this, the result is perfect. I have converted the same AVI file to an NTSC DVD with DVD santa, with no jerky results, although it seems to clip the edges off the picture. Please help - I am running out of blank disks!!![]()
Closed Thread
http://www.amazon.com/Forbidden-Planet-Walter-Pidgeon/dp/B00004RF9B
don't download warez.
Image jerky after converting a DVD to MKV
By siocnarf in forum Video ConversionReplies: 2Last Post: 22nd Apr 2012, 15:14 -
Converting mkv to dvd always results in an oversize iso
By Akhet in forum Newbie / General discussionsReplies: 3Last Post: 25th Sep 2011, 00:16 -
QT to FLV results in jerky video
By zvikico in forum ffmpegX general discussionReplies: 7Last Post: 6th Jan 2009, 20:26 -
AVI to DVD results in weird playback fault
By JustGreg in forum Video ConversionReplies: 0Last Post: 26th May 2008, 10:51 -
What program gives the best quality results, when converting AVI/DIVX/XVID
By Rockstar452 in forum Authoring (DVD)Replies: 3Last Post: 3rd Dec 2007, 02:19
