I have always created my DVDs by encoding my AVIs to Mpeg2 (with Procoder) and then authoring to create the final DVD (PAL in my region).
However there was always a slight loss of picture quality when comparing the AVI to the finished product, due to the encoding and authoring.
I note that now you can purchase DVD players that will play AVIs, and so, two questions come to mind....
(1) How to compress the AVI so that you can fit a reasonable amount of play time onto a DVD -R (I guess Xvid or DivX is the answer, but I am not sure)?
(2) Is the finished product (compressed AVI) going to look any better than my original AVI to Mpeg2 to DVD process ? If it is, then which path should I take....Xvid, Divx, or something else?
No, you wont get better quality using divx or xvid....or it depends on how many minutes/dvd you want and the source quality.
What is your source? avi doesn't say anything. avi-dv? captured avi with what video codec? interlaced? or what kind of avi. -
You will also want to do a test on your dvd player to see what types/specs of avi that it supports. The is a link for a test cd on the DVD Players page.
Google is your Friend
AVI to DVD-MPEG2 using SUPER
By hemang in forum Video ConversionReplies: 0Last Post: 19th Jul 2009, 23:25 -
converting Dv-Avi/Dvd Mpeg2 to Xvid format
By glenpinn in forum Video ConversionReplies: 56Last Post: 9th Jun 2009, 10:23 -
DV-AVI conversion to mpeg2 or DVD
By obadvw in forum Video ConversionReplies: 6Last Post: 17th Apr 2009, 07:59 -
Newbie questions on converting avi to mpeg2 and dvd authoring
By mlcampbe in forum Newbie / General discussionsReplies: 3Last Post: 4th Mar 2008, 14:08 -
Avi to DVD (mpeg2) in Mainconcept Mpeg Encoder, basic how to
By reboot in forum User guidesReplies: 31Last Post: 6th Aug 2007, 16:56
