I use a Kyocera phone from Virgin mobile, and it often can't pick up station in shopping mall or airport. I used to have a nokia phone which work great. My friend thinks the problem is the phone.
If I switch to a Nokia phone, will it help to get better connection ?
Well you should find out what freqency is mostly used in your area. 850Ghz 900Ghz 1800Ghz 1900Ghz, and by a suitable phone.
Nokia's you can change the broadcast power and speaker quality,
*3370# / #3370# Activate / Deactivate Enhanced Full Rate Codec (EFR) - Your phone uses the best sound quality but talk time is reduced my approx. 5%
*#4720# / *#4720# Activate / Deactivate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time -
In US, Virgin uses Sprint PCS CDMA network. Friend told me it is not as good as GSM network. I was looking into then option of adding a high gain antenna, but have not find one yet.
The question is which Nokia? Some phones are better than others. I've had three phones; a Motorola, a Nokia (which was not as good as the Motorola), and another Motorola (which was not as good as the Nokia).
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
But you know it depends on the service, because even though Verizon has great service, their phones suck... and then there's T-mobile, great service and phones... but not much of a wide selection. And the cooler Nokia's are on the cingular service... sprint/nextel service sucks in general!
You kind of also saying CDMA(Sprint & Nextel) is not as good as GSM. At the airport this thanksgiving, My Virgin mobile(on sprint) is the only one have receiving problem. I don't remember any problem when I was on Cincular. I am thinking about switch to the $99/year Cingular pre-paid.
For Drewzor : I though most cell phone are 850 or 980 MHz. Is the high frequencies for Spirnt PCS only. -
all the phone companys make good and bad phones. but i'd say in general nokia makes a better quality phone than kyocera lol. reception has to with tower placement is all. and cingular probably does have the best coverage out of anybody due to the merge with at+t.
Nokia N900
By SE14man in forum Newbie / General discussionsReplies: 0Last Post: 15th Jul 2011, 06:25 -
Audio file (mp3) will not play on Nokia phone.....Help
By efiste2 in forum AudioReplies: 2Last Post: 28th Apr 2011, 20:54 -
Best format for a Nokia N800?
By EwanG in forum Portable VideoReplies: 3Last Post: 17th May 2008, 05:04 -
Transfer foreign language DVD's to phone, Nokia N82, keeping SUBTITLES
By dohouch in forum Portable VideoReplies: 1Last Post: 3rd Feb 2008, 07:19 -
Converting AVI to either MP4 ofr 3gp on Nokia 5300 phone - a/v sync problem
By johnbdrysdale in forum Video ConversionReplies: 17Last Post: 13th Jul 2007, 22:56
