Hi all
Bright shiny newbie here and pretty cluless on the whole area of DVd etc.
I ahve been trying to cretae a DVD using Video DVD Maker from a file on my PC.
I set it off running when I leave for work and when I get home I get the External Exception error stated above.
I ensure no other software is running and my connection to the internet is disconnected.
I ahve only started having this prob;em in the last few weeks - never had problems the few times in the past when I have used this software.
Anyone any ideas/solutions ?
thanks very much
I'm clueless ... about everything
I can find 2 common sources for that error code. One is related to LinkSys and wireless communications, the other is caused by software trying to read/write a file that is already in use or "locked". I expect your problem is the 2nd reference and is the result of whatever Video DVD Maker is trying to do.
Try removing and reinstalling the software and check for any updates. Other than that, try different software.Google is your Friend -
Thanks for That Krispy.
i did have a bit of a search on Google and I also found the wireless thing and thought nope not me.
thanks again - may try re-installingI'm clueless ... about everything -
I re-installed and it's working again - thanks for that
StefI'm clueless ... about everything -
Well it's staretd doing it again and even after downlaoding a new (newer version) it's still doing it.
Any other pointers anyone amd does anyone know of any other FREE software that will let me convert various file formats to DVD annd then burn to DVD disc ?
Thanks allI'm clueless ... about everything -
There are quite a few. Take a look in the TOOLS section.
ConvertXToDVD is one of the more talked about, there are others.Google is your Friend -
that's great - thanks for pointing me in the right direction Krispy
I have since posting this also stumbled across and downloaded avi2dvd - which looks pretty good even though it takes ages and needs lots of free disc space.
thanks againI'm clueless ... about everything
Sabrent Video DVD Maker Video Capture Creator Anyone?
By Rayj00 in forum Capturing and VCRReplies: 3Last Post: 16th Aug 2011, 10:10 -
Kworld Expert dvd Maker - S-Video no picture
By johnstede in forum Capturing and VCRReplies: 3Last Post: 9th Aug 2009, 07:54 -
Unhandled exception error mencoder convert opendivx video - How to solve?
By melaos in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2009, 04:43 -
Womble MPEG Video Wizard - adding video files to dvd maker help?
By nightrider in forum Authoring (DVD)Replies: 3Last Post: 5th Mar 2008, 08:52 -
Vista Movie Maker and DVD Maker problems
By steve7510 in forum Newbie / General discussionsReplies: 5Last Post: 9th Jun 2007, 22:18
