  1. Guest
    What tools can I use on the mac to take a SVCD mpeg file and convert it to a DVD Studio Pro-ready MPEG? I'm trying to use Cleaner but it seems to be choking.
    d.
  2. you could try to convert the SVCD compliant MPG2 to quicktime with http://homepage.mac.com/linux/ (use a high-quality codec) and then convert back the quicktime to DVD compliant MPG2 by using the Apple MPG2 encoder which comes with DVDSP (needs a G4). If you don't have a G4 then try Astarte M-Pack. Be prepared for a long wait so try first with a 5-seconds clip.
    <font size=-1>[ This Message was edited by: major on 2002-01-15 15:28:36 ]</font>
