http://www.newegg.com/Product/Product.asp?Item=N82E16815167003 If i were to use this device will i get a better picture on my tv.
The plan is i have my computer hooked up to my SAMSUNG 23" FLAT PANEL HDTV LCD TV / MONITOR LN-S2338W and it is looks great i think the highest my video card can go is 1280 x somthing i think is like 720i its a radeon 9800 pro. But when i watch tv through time warner standard cable the (80 channels) sometime the picture is not clear. The device listed above is suppose to be able to put out a res. of
VGA Output Mode -
640x480 @ 60Hz/75Hz
800x600 @ 60Hz/75Hz/85Hz
1024x768 @ 60Hz/75Hz/85Hz
1280x1024 @ 60Hz
If i hook it to my tv will it make my picture clearer comming from my computer? Somebody help me please LOL!
I don't think that box gets you anything that you don't have now. It is a standard TV tuner that outputs to a computer monitor over VGA. It does nothing to help cable reception and would be worse than connecting the cable box directly to your TV.
Your LCD-TV already has a SD tuner and can accept VGA input from a computer card.
For computer connection, all you need is a dual head display card and run VGA to the computer. Best resolution to use is 1280x768. Next best is 1280x1024. -
Yeah I already have my computer hooked up to my TV using the dual vga inputs. I have it on my secondary desktop. My question is if i hook my time warner cable up to it then output it on my tv through my secondary desktop will the picture quality get any better thanks for the quick response.
I doubt it would do better than the TV tuner. See the other comment on getting the Time Warner HD cable box.Originally Posted by JDUB300X
Picture Quality on a HDTV connected to co-ax cable
By grk417 in forum DVB / IPTVReplies: 3Last Post: 1st Feb 2010, 00:23 -
HDTV gives stuttering picture
By thrilled in forum DVB / IPTVReplies: 13Last Post: 18th Nov 2008, 08:30 -
HDTV Picture Cuts at the Top
By Nitro89 in forum Off topicReplies: 0Last Post: 21st Sep 2008, 15:03 -
lcd hdtv or computer monitor for best picture?
By teevee in forum Newbie / General discussionsReplies: 9Last Post: 14th Feb 2008, 15:32 -
Lines in picture, HDTV PCI Card
By dnbrvr in forum DVB / IPTVReplies: 1Last Post: 2nd Dec 2007, 10:58
