Hi. I downloaded a mpg file and I wanted to add subtitles to it. Is there a way to do this? I haved tried to look for options and ways but I have no luck. thanks in advance. Im running windows xp 512 ram memory 40 gb harddrive.
cpu unkown sorry.
thanks
Is it mpeg 1 or mpeg 2?
Regarding the system info, try google for Sisoft Sandra lite. Free prog that helps you identify your system specs.Face the facts, find a solution, stick to it! -
PLease give us more information,
Do you want permanent subtitles in the video? then https://forum.videohelp.com/viewtopic.php?t=272736
Or switchable subtitles?
Do you want to convert to mpg? or something else? avi? dvd? -
hi thanks for the quick reply. I wanted to be able to make the subtitles optional. also I want to be able to convert to dvd I have vcg gear and convert to dvd which work great. Now My mission is to be able to put subs on the moves. thanks
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 09:22 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 18:30 -
Converting AVI to DVD plus Subtitles (Loss of quality on subtitles)
By somenho in forum ffmpegX general discussionReplies: 2Last Post: 27th Aug 2009, 10:23 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 17:28 -
Help with converting DVB subtitles to idx/vob subtitles
By Talayero in forum SubtitleReplies: 8Last Post: 21st Feb 2009, 18:10
