Hi. I 'converted' a VOB file into MPG format, but upon doing so, the audio... disappeared. I've ripped from the DVD, but when I attempt to fuse it with the video, TMPGEnc has this error:
27428 s packets cause buffer underflow. The MPEG file might cause error when played.
Then, when I play the file, there's nothing there. It plays for the correct amount of time, but its like the video/sound has been... erased.
Is there anyway to fix this?
Thanks.
Sounds like you are just getting the video portion of the VOB file when you extract the MPEG, try a separate extraction of just the audio portion. Then take those both in when using TMPGEnc to author another DVD.
TMPGEnc will also read audio/video material straight from a DVD or the VIDEO_TS file stucture on your PC's hard drive. That may be even easier than what you're doing.
Audio has problems in Windows Media Player but not in other audio apps
By brassplyer in forum Software PlayingReplies: 7Last Post: 23rd Sep 2011, 16:12 -
audio problems...............
By themediaman in forum Video Streaming DownloadingReplies: 6Last Post: 25th Dec 2010, 17:43 -
audio problems
By minigamer in forum Newbie / General discussionsReplies: 1Last Post: 21st Dec 2008, 11:03 -
Audio Problems
By macuser1960 in forum ffmpegX general discussionReplies: 9Last Post: 26th Feb 2008, 14:46 -
Problems w/Audio
By itsmevic in forum AudioReplies: 1Last Post: 9th May 2007, 00:53
