Hi, im interested in burning VCD's. Hopefully my first post is ok.
so far i have been burning VCDs from bin/cue files with Nero 6 for playback on standard DVD player.
what i want to do is convert .avi and .mpg/.mpeg to bin/cue files. i have been looking into it via google and various websites. i have EazyVCD(includesTMPGEnc), Cucusoft AVI to VDC/DVD and DVDx 2.2. it seems im able to convert .avi to MPEG1. what im not sure if it will playback as i dont have a DVD player. if this method will not work, is there some software for converting video files to bin/cue files?
Results 1 to 11 of 11
I changed your subject. PLease DON'T use subjects like newbie needs helps or similiar.
Yes you can use EazVCD, Cucusoft, DVDx, Tmpgenc and convert to VCD MPEG and then author/burn them with VCDEASY and it will work on dvd players. VCDEasy can also output to bin/cue files that you can burn with Nero. See our guides list, Convert and VCD.
Or use NeroVision, choose VCD, add the mpg,avi and convert and burn. -
ok, sorry bout the thread title.
i have been reading the guides but seem to find exactly what im looking for, EazyVCD only allows me to input the .evt files. i cant find any burning options. also i dont have Nero7 at the moment. just need a pointer in the right direction. -
You don't need nero 7. You can also use nero burning rom 6 and select VCD and then add avi,mpg files also.
Originally Posted by ultra777
Originally Posted by kschang
unfortunately the filter as blocked some of your words, so im not too sure what you're trying to say. -
That's not a filter. The point is just that you are looking at a two process and need to try both parts.
XP
Intel Celeron D 335 Prescott 2.8GHz Socket 478 Pro
600GB
2G
ATI Radeon X1600 Pro
GIGABYTE GA-8I848P-G Socket 478 Intel 848P ATX Int
Lite-On DVD SOHD-16P9S
Hauppauge WINTV-PVR-150 PCI Interface Tuner Card
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 16:42 -
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 00:59 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
