noob here...be gentle!
internet video links in WMP 9.0, IE 6, and Firefox are scrambled...all red green and yellow. What is the problem?
I figure it is probably something simple!
thanks in advance.
They all use DirectShow, so a bad DirectShow filter/codec is the prime suspect. You didn't by any chance install some codec pack?
/Mats -
when the problem started...no, i had not installed a pack.
after the problem started, i installed K'lite, which seemed to clear up the problem, for a bit. Now it's back. I uninstalled K-lite, and the problem persists.
How might i fix it? -
At times like this, some magic involving quartz.dll is often suggested. Search this site for it.
/Mats
Starting Point
By NeptuneDrew in forum Video ConversionReplies: 10Last Post: 19th Jan 2011, 15:40 -
Starting over with WinAvi problems
By alex0000 in forum Video ConversionReplies: 1Last Post: 3rd Feb 2010, 05:30 -
Problems in different equipment with .mpeg1 in Power Point
By carlosarano in forum Newbie / General discussionsReplies: 0Last Post: 22nd Feb 2009, 10:25 -
Starting a video with rootmenu or first chapter?
By psteel in forum Authoring (DVD)Replies: 6Last Post: 10th Feb 2009, 10:13 -
WMP 11 problems?
By rmunk in forum Software PlayingReplies: 2Last Post: 10th Dec 2007, 15:50
