Well, I know that when you burn a divx AVI file that has been acused by the AVI Chunk Viewer it will have sound problems. It happened to me once, I learned how to fix it with VirtualDub, and that's ok.
But today something happened: I burned to a DVD a dvix file that AVI Chunk Viewer did NOT get. So I thought it was ok. When I watched it there was no sound though. I corrected it via VirtualDub, reburned in another DVD and it worked fine.
My question is: how can I be sure if the file is ok BEFORE burning it so I won't waste medias?
Anyone?
Results 1 to 1 of 1
Help plz. :Capture AVI issue : Bad chunk in frame data: Invalid length
By chindoo in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jul 2011, 19:51 -
Avi chunk viewer?- what is this?!
By vanjo in forum Software PlayingReplies: 21Last Post: 29th Oct 2010, 02:20 -
No more hdtv detection
By bjjaddict in forum ComputerReplies: 0Last Post: 27th Nov 2009, 15:09 -
avi chunk viewer
By agent222 in forum Video ConversionReplies: 5Last Post: 15th Nov 2007, 10:03 -
Junk chunk size calculation
By maestro777 in forum ProgrammingReplies: 8Last Post: 1st Jul 2007, 05:16
