Anyone know how I would convert a vcd to a dvd? Never tried this before. Is there special software I need to be able to do this? Thank you
VCD video format is already DVD compatible. You need just to change the audio sampling rate from the VCD standard of 44.1Khz to the DVD sampling rate of 48Khz. TMPGEnc DVD Author can do this automatically. That's probably the easiest method.
For the DVD format, see 'WHAT IS' DVD to the upper left. <<<<<< -
Tmpgenc DVD Author is probably the simplest way. Use ISOBuster to extract the mpeg-1 stream from the VCD structure. Import this into TDA, which will upsample the audio to a compliant 48 kHz, and yu are done. Create a menu and compile to finish.
Read my blog here.
DVD to VCD... HOW?
By aglara in forum DVD RippingReplies: 3Last Post: 17th Jun 2010, 00:29 -
VCD to DVD
By Argon in forum MacReplies: 4Last Post: 5th Oct 2008, 11:01 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 20:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
