Hi everyone i'm new to this forum so let me just say hi & if this question has been posted anywhere else before I apologise. Well my problem seems to be this, i've joined together some avi files with virtual dub & its worked great. Unfortunately where i've joined the files together there must be a gap or something in the audio since I get a high pitch squeal for a millisecond or 2 while the next file starts to play. Anybody any ideas on how I go about correcting this???thanks in advance.![]()
Seen this only happen once before .
Load video into vdub
Set audio to full processing , set compression to none , set conversion to 41khz , 16bit , stereo .
Save as wav
You have two choices to correct the squeel .
Audocity or goldwave , there are other's .
Loads wav into prefered audio editor .
Locate area with issue , use filter's to "squash" effected area ... not to almost silent point on line .
(Too many filters to recall off hand)
Playback the file after it's saved ... you may need to do this more than once , and it may never be perfect , but you will have removed the high pitched noise problem . -
oh right can I just use a simple wav editing tool to sort this issue out then?should be able to get away with using nero wave editor in that case shouldn't I?thats great thanks for the info mate sounds so simple now that you've told me this dunno why I didn't think of it myself
8)
Trouble with opening flv files in Virtual Dub.
By drumwork83 in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2012, 22:53 -
noise where joined 2 avi files
By coyote2 in forum EditingReplies: 20Last Post: 13th Oct 2011, 22:19 -
Can't edit MP4 files in Virtual Dub
By brevardo in forum EditingReplies: 25Last Post: 10th Mar 2011, 21:18 -
Queue files in Virtual Dub Mod?
By leogeo in forum Newbie / General discussionsReplies: 2Last Post: 2nd Nov 2007, 03:13 -
I can't join two avi files with Virtual Dub
By Hopalong Cassidy in forum Newbie / General discussionsReplies: 4Last Post: 10th Jun 2007, 17:21
