    Nov 2006
    Just wondering if there is a program out there that is like Nero Vision 4. Nero seems to work fine, except when I try to play a file and create chapters. The video always stops, freezes, etc. I do like how easy it is to use your own background pic, etc.
    It doesn't work fine if it freezes....or if it just freezes on your standalone dvd player then it's probably crappy dvd media. Does the converted dvd work on your computer?
    Or convert with something else like ConvertXtoDVD and author the output with TDA if you want more advanced menus.
    Nov 2006
    Well, it turns out that it was the old version of Nero vision that was causing the issues with not being able to create chapters. I upgraded to the latest version of Nero Ultra and vision works when creating chapters.
    As far as the media goes, I only use verbatim's or Fuji's
