"Your search yielded no results"
So I ask this question.
How do I get the stupid little chirp out of
the audio when encoding to vcd?
I am using ffmpeg mpeg1, 352x240, 1150 kbps, 29.97 fps, no crop
The standard vcd settings.
audio codec mp2
bitrate 224
sampling 44100
channels stereo
mode cbr
ffmpeg options checked "high quality"
Using mac mini os x tiger
VCDs have minimal error correction, so if intermittent chirps are showing up only when you playback the VCD, but not when playing the file from your HD, then your problem is a poorly burned disc. Reburn, possibly with better media.
If you're hearing these chirps even before you burn a disc, but they aren't present in the original sourcefile, then it's possible that the source doesn't quite conform to specs. Demux, then separately transcode the audio using a different tool, then see what happens.
dvddecrypter stop recognize dvd in drive, got img burn,it stop recognize
By ninjinturdle in forum Authoring (DVD)Replies: 3Last Post: 21st Jun 2011, 12:30 -
Stop Motion help?
By leth in forum Newbie / General discussionsReplies: 1Last Post: 30th Nov 2010, 01:12 -
Is there anyway to stop over scan?
By andre477 in forum Newbie / General discussionsReplies: 4Last Post: 25th Oct 2008, 14:20 -
Chapter stop question
By Ronny G in forum Authoring (DVD)Replies: 2Last Post: 18th Feb 2008, 10:31 -
Cannot stop recording!
By paulhodson in forum DVD & Blu-ray RecordersReplies: 3Last Post: 7th Jan 2008, 12:41
