Can an invividual pc be tracked thru an open wifi spot?
Results 1 to 10 of 10
AnonymousGuest
If I login at an open access point, will my pc have a unique id(can MACs be id)?
if you are visting a friend or happen across someone's open WIFI connection.. NO, YOU CAN'T BE PERSONALLY TRACKED OR FOUND(back to you).. Just your friends Internet connection or the persons WIFI connection you used.
Well, actually, you can be tracked. Since you are TRANSMITTING while you are logged on, a dedicated entity (person, police dept, anti-terrorist hit squad, government, phone company) can EASILY locate your transmitting computer. With the equipment in place, you can be located two seconds after you begin trying to access the open connection. In fact, they will have your location BEFORE you even get on the internet.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
AnonymousGuest
I'm speaking of after the fact. If you go to Starbuck's and leave after logging out, will they have a record of your login?
Assuming that you are not required to LOGIN, then you would be truly anonymous. A PC didn't used to have a unique ID/serial number of the electronics (some of the newer processors DO have a hardcoded unique identifier - IIRC, thanks to M$). I don't know MACs, but I thought that they DID have a unique identifier.Originally Posted by Dr.Gee
If you do login, then you have left a trace.ICBM target coordinates:
AnonymousGuest
Then why doesnt the RIAA go after these deep pockets(Starbuck's) where a ton of illegal downloads are surely occuring?
give it time....
I am just a worthless liar,
I am just an imbecil
Optimal tracking for video != optimal tracking for audio
By miamicanes in forum RestorationReplies: 4Last Post: 16th Oct 2014, 12:52 -
WIFI AC and WIFI AD coming in the next few years
By yoda313 in forum ComputerReplies: 0Last Post: 31st May 2011, 10:01 -
Point to point sharing with wifi adapter and wifi router?
By yoda313 in forum ComputerReplies: 5Last Post: 17th Jul 2008, 18:47 -
WiFi on a motherboard ?
By Dash1 in forum ComputerReplies: 6Last Post: 3rd Nov 2007, 08:02 -
Have you upgraded to WIFI N yet?
By yoda313 in forum PollsReplies: 14Last Post: 25th Jun 2007, 20:16
